Project Registry
The Registry contains the list of all project known to an installation of Altair Accelerator software.
% vovproject list
PROJECT OWNER HOST PORT STATUS
1 IDT johnak linux33 6425 stopped
2 TEM johnak mac05 6430 stopped
3 chip1 johnak maclap 6250 running
4 chiptest johnak mac05 6442 obsoleteThe registry is normally in the directory $VOVDIR/local/registry but an alternative location may be specified by setting the environment variable VOV_REGISTRY.
The registry directory contains one entry per project. Each entry is a file with a
name of the form project@host. The file is written in Tcl
syntax and contains key information about the project. This is known as a
regentry file.
As of version 2015.03, the registry places the regentry files for each user's projects under a subdirectory named for their user account. In the following example, the file would be in $VOV_REGISTRY/cadmgr/vnc@rtda01.
The vovproject command should automatically move a project's regentry file into the user-specific subdirectory the first time the project is started on 2015.03. To revert to an earlier release, you must move the regentry file manually.
vnc@rtda01 may contain the following
information:
# -- This registry file is generated automatically. DO NOT EDIT!
# -- Copyright © 1995-2025, Altair Engineering
set host "rtda01"
set project "vnc"
set product "nc"
set owner "cadmgr"
set startdate 1331080351; # Tue Mar 6 16:32:31 2012
set version "2015.03"
set protocol "8.2.1"
set protocolid "120150304"
set swd "/remote/proj/cadmgr/vnc"
set port 6271
set pid 3153
set description {}
set status "running"
set vovdir "/remote/release/VOV/2015.03/linux64"
set timestamp 1436228536; # Mon Jul 6 17:22:16 2015
set swdmap(keys) {unix canonical registry windows full }
set swdmap(unix) {/remote/proj/cadmgr/vnc}
set swdmap(canonical) {${VNCSWD}}
set swdmap(registry) {/remote/proj/cadmgr/vnc}
set swdmap(windows) {r:/VOV/vnc}
set swdmap(full) {/remote/proj/cadmgr/vnc}The project's regentry file is initially created by the vovproject
create command. Thereafter, the running vovserver
updates its registry entry file every 10 to 30 minutes. During normal shutdown, the
server updates the timestamp to the shutdown time and sets the
status value to "stopped".
% vovproject list% vovproject list -all -lvovproject
list command will show 'obsolete' for projects whose
underlying status is running but whose timestamp is older than
1800 seconds (1/2 hour). % vovproject start project-name
% vovproject enable project-name
% vovproject listTo determine whether a project's server is running is to use the UNIX ps(1) command on the machine which hosts the project.
Administrator Concerns about the Registry
Because creating a project also creates the registry entry, the registry directory must be on a writable filesystem with permissions permitting users to create files there.
local directory among the versions. To set this up: - Move the local directory as a sibling to the version directories.
- Create symbolic links from the local directory of each version to the shared directory.
Missing Registry Entry Files
- If the vovserver is running, it will re-write the registry file if possible.
- If the vovserver was not running, you cannot start it
using
vovproject, because the regentry file that contained the project metadata is gone.
+ determine the machine on which to start the vovserver program by
examining the project's setup.tcl file
+ get a shell as the project owner on that machine
+ change to the parent of the <project>.swd directory
+ enter the project environment by
% ves <project>.swd/setup.tcl
+ start vovserver
% vovserver -jsb $VOV_PROJECT_NAME
