Project Creation Overview
An overview of setting up a new project:
- Set up the server working directory with the necessary files. The default values for the files depend on the selected type. The list of available types is available in the directory $VOVDIR/local/ProjectTypes.
- Start the server and the taskers for the project.
To create a new project, use
vovproject create. To explicitly
specify the working directory, use the option -dir. To explicitly
specify the project type, use the option -type. Example:
% vovproject create [-dir serverdir] [-type type] [-port number] projectConnecting to the running server requires an enabled shell in which the environment
variables VOV_HOST_NAME and
VOV_PROJECT_NAME are properly set. To enable a shell, which is modifying an existing
shell:
% vovproject enable project
If the project has already been created, the server can be started and stopped as
follows:
% vovproject start project
% vovproject stop project
