Check All Files in a Project
When you request a run, the FlowTracer server checks the timestamp of all primary inputs in the up-cone of the target.
To check all files in the up-cone, instead of only the primary inputs, use the VOV_VW_CHECK_UPCONE variable, which tells the wrapper to check all files in the up-cone at run time.
vovcheckfiles: Usage Message
DESCRIPTION:
Check the timestamp of all files in a project.
This is an expensive operation, so this script
implements a semaphore to avoid concurrent checks.
USAGE:
% vovcheckfiles [OPTIONS]
OPTIONS:
-v -- Verbose
-h -- This help
EXAMPLES:
% vovcheckfiles -h
% vovcheckfiles
% vovcheckfiles -v
If the timestamp of any file in the project has changed, for example by being modified by an editor or other program run outside of the flow, the vovserver is notified of the change. This may cause the down-cone of the modified file(s) to be marked INVALID.
The vovcheckfiles command tries to prevent more than one instance of itself from running concurrently. See Troubleshooting for more information.
