| File tail name |
Files |
255 |
This is everything after the directory name |
| Full path name |
Files |
1023 |
128 |
16000 |
maxPathLength |
Windows limit is 259, Linux is 1023 or 4095 |
| NFS delay |
Files |
0 |
0 |
300 |
nfsdelay |
The number of seconds to wait before trusting the NFS cache
for file properties |
| Time tolerance |
Files |
0 |
0 |
600 |
timeTolerance |
The max time skew between the server and any host used as a
tasker |
| Child processes |
Jobs |
40 |
This is the number that are tracked for job
statistics |
| Command length |
Jobs |
40960 |
128 |
100000 |
maxCommandLineLength |
| Job array size |
Jobs |
10000 |
10 |
100000 |
maxJobArray |
| Job class length |
Jobs |
No limit |
Limited by available memory only |
| Job directory |
Jobs |
1023 |
Limited by OS |
| Job environment |
Jobs |
512 |
128 |
16000 |
maxEnvLength |
Used named environments if more characters are needed |
| Job legal exit codes |
Jobs |
100 |
Space-separated list |
| Job name length |
Jobs |
No limit |
| Job project length |
Jobs |
No limit |
| Job resources |
Jobs |
1024 |
128 |
16000 |
maxResourcesLength |
| Resource map length |
Jobs |
1024 |
512 |
64000 |
resmap.max.map.length |
| Dependency levels |
Nodes |
4095 |
This is the max number of dependency levels in a flow graph
including files and jobs |
| Number of smart sets |
Sets |
50 |
10 |
5000 |
maxSmartSets |
Too many smart sets can result in reduced server
performance |
| Selection rule |
Sets |
511 |
| Set name |
Sets |
511 |
| Property name length |
Properties |
255 |
16 |
1024 |
prop.maxNameSize |
| Property value length |
Properties |
131071 |
128 |
1048576 |
prop.maxStringSize |
| Tcl variables |
Scripts |
2147483647 |
Tcl variable values are limited to 2GB which may restrict
some strings |
