Node Editor
By default, the Node Editor has six tabs :
- Job
- Annotations & Properties
- Why?
- O:Stdout
- O:Stderr
- O:Log
Add Tabs in the Node Editor
To add new tabs in the Node Editor, use the procedures
::VovGUI::addOutputTab and
::VovGUI::addInputTab . These procedures require 3 arguments:
- The label to be given to the tab.
- The regular expression to match the file to be displayed.
- A special expression to determine if the tab is to be displayed. This
expression can take one of the following forms:
- Argument
- Effect
- Show tab always
- +toolname
- Show tab only for jobs that use tool 'toolname'.
- -string
- Show tab only for jobs with a command line that contains the string 'string'.
- TOOL~value
- Show tab for jobs whose tool matches 'value'. Example
TOOL~spice - COMMAND~value
- Show tab for jobs whose command line matches 'value'.
- ENV~value
- Show tab for jobs whose environment matches 'value'.
- STATUS~value
- Show tab for jobs whose status (in string format) matches 'value'.
Here is an example of a gui.tcl file.
# Fragment of gui.tcl
# Show the VNC log file for all jobs that have tool equal to "vwrap"
::VovGUI::addOutputTab "vnclog" {/vnc_logs/[0-9]+/[0-9]+\.[0-9]+$} "-vwrap"
::VovGUI::addOutputTab "Err" {/.*\.err$} "+"
::VovGUI::addOutputTab "Log" {/.*\.log$} "+"
::VovGUI::addInputTab "C-src" {\.c$} "-gcc"
