Multi-User Mode Setup: Project Owner
All users who are expected to share the FlowTracer project must belong to a common UNIX group.
Note: The IT department should create a UNIX group, if one
doesn't already exist, that includes all the users who need to work on this shared
project. (For these instructions, let's use a group called "designers".)
The steps that follow should be completed by the project owner.
The project owner will create a new project, ensuring that he/she is using the
designers UNIX group as the default group. This can
be ensured by running the UNIX command
newgrp:% newgrp designers % source<installation_directory>/<version>/<platform>/etc/vovrc.csh % vovproject create <projectname> % vovproject enable <projectname> -
Create a vovusergroup called "designers" from the UNIX group "designers".
This will add all the users of the UNIX group "designers" as members of the vovusergroup "designers".
% vovusergroup populate designers -unix designers -
Assign the LEADER role to the vovusergroup designers. For this, modify the
security.tcl file to include the following line:
vtk_security -group designers LEADER + -
Set the environment variable VOV_FT_MULTIUSER to tell
vovlsfd that FlowTracer is running in multi-user mode.
In this mode,
vovlsfdwill only accept and submit jobs for the user who started this instance ofvovlsfd. - Restart the project so all the new settings will take effect.
Start
vovlsfdto enable taskers to submit jobs to LSF.The project is now ready for use by other members of the designers group.
