Multi-User Mode Setup: Leaders
The Leaders are the members of the designers group.
Change your current default UNIX group to be
designers.
% newgrp designers -
Enable the multi-user project.
Note: Since you are enabling a project owned by a different user, you will need to use the -u flag on the vovproject enable command line to specify the user that the project is owned by.
% source <installation path>/common/etc/vovrc.csh % vovproject enable -u <owner> <projectname> % vovconsole -
Set the environment variable VOV_FT_MULTIUSER to tell
vovlsfdthat FlowTracer is running in multi-user mode. -
Start
vovlsfdto enable taskers to submit jobs to LSF. (Note, each LEADER will need to start his/her own copy ofvovlsfdfrom vovconsole.)Now you can view the jobs created by other users, as well as create your own jobs
