Use Makefiles
If your flow is currently managed by Makefiles, you may perform a conversion of the Makefile into a trace using the utility vovmake.
- To convert Makefiles to TCL flows use the following command line:
% vovmake -f Makefile - vovmake executes the following steps:
- Parse the Makefile with gmake_with_vov_extension to generate a Tcl representation of the dependencies in the Makefile
- Use vovbuild to parse the file and to build a flow
- Request an update (a retrace, in FlowTracer lingo) of all the jobs thus created
There are limitations to this approach, because not all Makefiles represent a proper flow. The conversion may not be 100% complete. This is not necessarily bad, as an improper flow will not produce predictable results anyway.
Options for vovmake
| Option | Description |
| -help | Show the usage. |
| -clean | Cleanup the auxiliary directories and scripts created by vovmake. |
| -wrapper <WRAPPER> | Choose the wrapper to prefix each tool invocation. By default, no wrapper is used, so that runtime tracing is not active on the resulting flow. This means that the default behavior is to use exactly the dependencies specified in the Makefile. |
| -res <RESOURCES> | Resource expression to be used with the jobs in the flow. By default, the resource expression is empty. |
DESCRIPTION:
This is a script used to convert makefiles into FlowTracer flows.
1. First the makefiles are interpreted by a modified gmake,
called gmake_with_vov_extension, which contains some
Altair Engineering extension and supports the option -F to dump
the dependencies into Tcl file.
2. The resulting Tcl file is then mapped into a flow by means of the
script $(VOVDIR)/tcl/vtcl/vovmaketoflow.tcl.
USAGE:
% vovmake [VOVMAKEOPTIONS] [gmake_options]
VOVMAKEOPTIONS:
-help -- Print this help.
-clean -- Just cleanup the generated files.
-nocleanup -- Do not cleanup temporary files
(for debugging).
-gmake <GMAKEBIN> -- Use specified gmake binary
This must be one with the Altair Engineering
extensions.
Default gmake_with_vov_extension
-build "options" -- Options passed to vovbuild, with flow
-version -- Show gmake version and exit
-wrapper <dfltwrapper> -- Specify default wrapper for jobs in
flow. It is passed to vovbuild.
-run [ft|no] -- Run Flowtracer to get more information about
input makefile. Default is ft.
EXAMPLES:
% vovmake -help
% vovmake install
% vovmake <SOME_MAKE_TARGET>
% vovmake -clean
% vovmake -nocleanup all
% vovmake -gmake ~/bin/my_gmake_with_vov_extension
% vovmake -wrapper vrt
% vovmake -build "-env BASE" install
To find the options of vovmaketoflow.tcl, you can use
% vovbuild -f $VOVDIR/tcl/vtcl/vovmaketoflow.tcl -- -help
Conversion Examples
########## Simple Makefile for training with vovmake
# Experiment 1: % vovmake all
# Experiment 2: % vovmake -wrapper vw all
all: dd ee
bb: aa
cp aa bb
cc: bb
cp bb cc
dd: cc
cp cc dd
ee: cc
cp cc ee
% cp $VOVDIR/training/vovmake/Makefile_1 Makefile
% vovconsole -view graph -set System:nodes &
% touch aa
% vovmake
% vovforget -allnodes
% vovmake -wrapper vwvovmake Uses GNU gmake with Some Extensions
The vovmake script uses gmake_with_vov_extension to parse the Makefile and dump it into a Tcl script. The program gmake_with_vov_extension is a variant of GNU-make 3.81. In compliance with the GNU license, the source code for gmake_with_vov_extension is included in the distribution in $VOVDIR/src/vmake381_src.tgz.
