Ignore Links into the DesignSync Cache
If you use DesignSync, you want to ignore links to the DesignSync cache.
This can be done by setting the variable VOV_SYNC_CACHE_DIR to the full path to the DesignSync cache. The symlinks will not be resolved to the final name, but will keep the original symlink name. The nodes are still present in the graph (they are not excluded, as with exclude.tcl).
% setenv VOV_SYNC_CACHE_DIR `vovequiv -p /opt/local/dssc/sync_cache` We use vovequiv -p ... to eliminate any symbolic links in the path
of the DesignSync cache itself.
The variable VOV_SYNC_CACHE_DIR is read by the wrappers (vw, vov, ...) at runtime.
% setenv VOV_SYNC_CACHE_DIR /opt/local/dir1/sync_cache:/remote/.sync/cache_dir% ls -lrt top.v
lrwxr-xr-x 1 ged staff 126 Aug 9 14:37 top.v ->
/opt/local/dssc/sync_cache/sfb/sfbf04ef93dg158ed-1.2-1310712769-0FlowTracer will display the file as top.v when the VOV_SYNC_CACHE_DIR environment variable is correctly set.
The real file name sfbf04ef93dg158ed-1.2-1310712769-0 will not be displayed.
-d option in
vovequiv to see how symbolic links are mapped:
% vovequiv -d -p aaa
vovsh Aug 29 09:49:39 SYMLINK: SYNC_CACHE_DIR is '/remote/projects/sync_cache'
vovsh Aug 29 09:49:39 SYMLINKS: Replaced '/home/casotto/projects/ac8head/testing/main/dssc_test_run/abc.txt' with '/home/casotto/projects/ac8head/testing/main/dssc_test_run/tmp_sync_cache/1234567890-1.2-123456789CACHE_FILE1234'
vovsh Aug 29 09:49:39 SYMLINK: path '/remote/projects/sync_cache/1234567890-1.2-123456789CACHE_FILE1234' is in CACHE_DIR
