Start Run - Run Jobs Depending on Changed Inputs
The CLI Program vsr - Vov Start Run
The command line program vsr triggers the FlowTracer system to generate a runtime trace based on the dependency graph in order to schedule and run jobs that depend on the changed inputs. The system will continue this until no more jobs need to run because of changed inputs.
The name of this program was created to be the acronym for "Vov Start Retrace".
This command is used when input changes are ready to apply, and you want all the dependency processing to start running. This is similar to requesting a recalc in a spreadsheet when all the changes have been made.
vsr
Retrace a list of files and directories. Use option -set to retrace sets of nodes.
vsr: Usage Message
DESCRIPTION:
With the option '-set' you can retrace sets of nodes.
USAGE:
% vsr -help
% vsr -set <setName>
% vsr [options] <id_or_file_or_directory> ...
OPTIONS: All options can be abbreviated to one letter,
except -safe, -fast, -aggressive, and -select.
NORMAL FLAGS:
-help This message.
-v Increase verbosity.
-all Retrace the entire design (abbreviation -a).
-force Force retracing of failed nodes too.
Abbreviation: -f
-hier If target is a set with subsets, retrace all subsets.
-kick Kick a file: update all files that depend on it.
-priority sp[.xp]
Specify the scheduling priority (sp) and optionally
also the execution priority (xp).
Both sp and xp can be one of:
LOW, NORMAL, HIGH, TOP or an integer in [1-15].
(Explanation: TOP=15 HIGH=8 NORMAL=4 LOW=1)
-resources <r> Additional resources to be used for the jobs to be
retraced. Abbreviation: -r
-select <rule> Retrace nodes that match the given selection rule.
-set <setName> Retrace all nodes in given set.
-recompute If used with -set, forces recomputation of named set.
-timeout <timeSpec>
Wait for events for specified time, then exit if
no event arrives.
-nowait Exit immediately after issuing retracing request.
This is the same as "-timeout 0"
ADVANCED FLAGS:
-safe All dependencies are computed again (default).
-fast Retrace without computing the dependencies again.
-aggressive Like safe, but retrace in parallel across barriers.
-crossbarriers Schedule jobs across barriers
Abbreviation: -cb
-skipcheck Do not check the upcone of the target.
-checkall Check all files in the upcone of the target.
-nocheck Do not check files in directories to retrace.
Implies -skipcheck.
-unblock Check blocking files before doing retrace.
-retry <n> Repeat retracing <n> times. The default is 1.
-converge Retry until the flow is complete or until the
failed/invalid job count is unchanged after 3 retrace
loops. If a retry number is specified, converge will
limit the number of retrace loops to that number.
-statusreps <n> Override the default of 3 for the maximum number of
repeated failed/invalid job counts for the converge
option.
EXAMPLES:
% vsr -help
% vsr
% vsr -priority high.high fileABC
% vsr . -crossbarriers
% vsr . -cb
% vsr ../a ../b ../c/file
% vsr -nowait -all
% vsr -timeout 3h
% vsr -retry 4 -timeout 100
% vsr -set 'Stuff to do'
% vsr -recompute -set 'Stuff to do'
% vsr -select 'isjob tool==gzip'
Examples
You can request a run for a given target file with:
% vsr fileName_or_VovIdYou can run all jobs in a directory with:
% vsr directoryNameYou can target a run to be a group of nodes that make up an entire set with:
% vsr -set setNameAs a special case, you can run everything in the whole design. Use the system defined
private set
System:nodes with:
% vsr -allSet the Priority with the option -p:
% vsr -p high directoryNameIf you change a file and would like to retrace starting with that changed file,
running jobs that are affected by the change, use:
% vsr -kick name_or_VovId_of_changed_file
