Library-based Interception
This method is a technique where the system I/O library is replaced by a modified version that has been instrumented with FlowTracer. Without changing the source code of the tools, this technique is in fact a form of low-level instrumentation. The routines in the modified I/O library behave exactly as those in the original system library, except that a few additional calls to the VIL functions are made to declare the I/O behavior of the tool.
Because the runtime interception library is sensitive to all file I/O, it is most important to have a well-defined exclusion file to eliminate uninteresting files from the resulting trace. No other preparations are necessary.
% vrt cc -o prog src1.o src2.o src3.oThis technique is avalable for Linux.
Requirements for Linux
% file /bin/ls
/bin/ls: ELF 32-bit MSB executable SPARC Version 1, dynamically linked, stripped
