GUI Customization
Both the vovconsole's main GUI and its Node Editor GUI can be customized with the gui.tcl file.
- $VOVDIR/local
- The server configuration directory (.swd)
$VOVDIR/local/gui.tcl is installation-based customizations, while $SWD/gui.tcl project-based customizations. $VOVDIR/local/gui.tcl will always be sourced, followed by $SWD/gui.tcl (if it exists). Knowledge of Tcl/Tk is required in order to customize the vovconsole GUI.
You can see the pinkish labels containing "Customize
<TkWidgetType> <TkWidgetPath>"
information messages. These labels point out where customization may occur, and what
Tk widget path to use. On the main GUI, both the menu (type=menu
path=.menubar) and tasker monitor frame
(type=frame path=.fTaskerMonitor.gridbuttons) are customizable.
Additionally, new tabs can be added to the Node Editor.
Set a Custom Title
To set a custom title, call the procedure ::VovGUI::setConsoleTitle
in the gui.tcl file. This procedure takes a single argument:
the custom string that will be displayed at the beginning of the vovconsole title.
Implementing ::VovGUI::customize
::VovGUI::customize is called after many of the
elements of the vovconsole have been created. You can create your version of
::VovGUI::customize in your gui.tcl file
and operate on the elements. For example you can add a new command in the pop-up
menu, a new button along the bottom of the Node Editor, or some artwork in the
menu-bar at the top. A very good knowledge of Tcl/Tk is
required.#
# This is a fragment of gui.tcl
proc ::VovGUI::customize { widget } {
set mycompany "mycompany"
VovMessage "Opportunity to customize window $widget" 3
switch -glob $widget {
".menubar" {
menu $widget.$mycompany -tearoff false
$widget add cascade -label {MyCompany} -menu $widget.$mycompany -underline 2
$widget.$mycompany add command -label "MySettings" -underline 0 -accelerator 'S' -command {exec /usr/X11/bin/xterm}
".popupNode" {
$widget add command -label "DoSomething" -command "::VovGUI::MySpecialCallBack"
".vgui-nodeviewer.fTop.toolbar" {
# Add a button along the Node Editor's bottom toolbar
button $widget.newButton -bd 1 -text "Report Issue" -command "::VovGUI::ReportIssue"
pack $widget.newButton -side left -padx 10 -pady 2 -fill y -expand 0
"*.xleFormat" {
### Customize the list of formats in "list mode".
$w insert end "@ID@ @JOBNAME@"
".nodemenu" {
# Customize the right click popup menu in the set browser
$w add command -label "Do something" -command MyCallback
# Example of call back
proc ::VovGUI::MySpecialCallBack {} {
set nodeId $::VovGUI::currentNodeID
set selection [::VovGUI::GetSelection $::VovGUI::currentWidget sel 0]
puts "DO SOMETHING WITH $nodeId"
puts "Selection = $sel"
puts "Widget = $::VovGUI::currentWidget"
proc ::VovGUI::ReportIssue { } {
# This procedure will determine which Node Editor tab is active, and will produce
# a message box popup with the contents of the tab. This only applies to
# the 'Why' and later tabs.
# Get notebook widget handle
set nb ".vgui-nodeviewer.fTop.vwxNodeEditor.xnbMain"
# Figure out 'active' tab
set activeTab [$nb raised]
# Get text contents of active tab
switch $activeTab {
#"node" { set txt "" }
#"annotations" { set txt "" }
"why" { set txt ["$nb.nbframe.why.xstWhy.text" get 1.0 end] }
"out-1" { set txt ["$nb.nbframe.out-1.xstContent.text" get 1.0 end] }
"out-2" { set txt ["$nb.nbframe.out-2.xstContent.text" get 1.0 end] }
"out-3" { set txt ["$nb.nbframe.out-3.xstContent.text" get 1.0 end] }
"out-4" { set txt ["$nb.nbframe.out-4.xstContent.text" get 1.0 end] }
"out-5" { set txt ["$nb.nbframe.out-5.xstContent.text" get 1.0 end] }
default { set txt "Tab '$activeTab' functionality not supported" }
# Create message box popup with the text contents
set answer [tk_messageBox -icon question -type yesno -title "Do you want to submit the issue?" -parent .vgui-nodeviewer.fTop -message "$txt"]
if {$answer == "yes"} {
# Add code here to email the text to your issue tracking system
Add a Logo to the Console
.menubar
widget.#
# EXAMPLE: Add a logo to the Menu Bar.
proc addMyLogo {} {
if [winfo exists .menubar] {
set ppm /path/to/mylogo.ppm
set img [image create photo -file $ppm]
.menubar add command -image $img
# This is a bit tricky.
after 3000 { ::VovGUI::addMyLogo }
Change Colors of Jobs Based on Exit Status
vtk_transition_color_control to choose the color used to
represent VALID and FAILED jobs in the console, depending on the exit status. For
example, to display VALID jobs that exited with status 10 using the color "pink",
write:
# Fragment of gui.tcl
vtk_transition_color_control SET_VALID 10 pink# Fragment of gui.tcl
vtk_transition_color_control SET_FAILED 255 brownReference documentation for vtk_transition_color_control can be
found in the VOV Reference Guide.
Choose the Editors Depending on File Types
::VovGUI::addFileEditor to describe the editor to
be used for files with a given suffix. Example:
::VovGUI::addFileEditor ".lef" "xterm -e vi"Change Default Priorities and Retrace Flags
# Controls on priority (case-sensitive)
set ::VovGUI::retrace(priority) Low
set ::VovGUI::preference(retrace.priority) LOW
# Controls on mode
# Values for retrace(mode): force crossbarriers skipcheck aggressive or SAFE
set ::VovGUI::retrace(mode) "crossbarriers force skipcheck"
set ::VovGUI::preference(retrace.force.failed) 1
set ::VovGUI::preference(retrace.crossbarriers) 1
set ::VovGUI::preference(retrace.aggressive) 0
set ::VovGUI::preference(retrace.skipcheck) 1
# Finish by refreshing the console
::VovGUI::UpdatePriorityFooter
When changing the VovGUI::preference
nn54;lr(retrace.XX) options, you will get two Save options: one option
will save the preferences to your home directory, and the other with save them to
your project directory (SWD).
- GUI checkboxes will not reflect the default settings: Use
set ::VovGUI::retrace(X). - GUI checkboxes will reflect what you have set the default to be and
use that default, use
set VovGUI::preference(retrace.X)
