Altair FlowTracer and ClearCase
Here is a list of suggestions to keep in mind when working in a ClearCase
environment.
- The most important tool in ClearCase is called cleartool. Most users create an alias called "ct" or "cl". We only use the full name cleartool.
- Add the path to cleartool to the BASE environment. It often is in /usr/atria/bin.
- We support "single-view" projects. You have to start the server AFTER
setting the
view.
% cleartool setview MYVIEWNAME % vovproject start MYPROJECTNAME - You need to know that to execute a command in a view you can use the
following syntax:
% cleartool setview -exec "COMMAND" MYVIEWNAMEThis is what we do in vovtaskerstartup to start a vovtasker in the requested view.
Version Extended and View Extended Dependencies
For files in the VOBS, FlowTracer can track both.
- The version extended name (Example: /aa@@/main/3). These files will never change timestamp.
- The view extended name (Example: /view/MYVIEW/aa These files may change timestamp.
This capability is activated by setting the variable VOVCLEARCASE to the value
ENABLED. We recommend you do this in the setup.tcl file.
# Add this line to the setup.tcl file.
setenv VOVCLEARCASE "ENABLED"
