Flow Library Procedures
This section documents the procedures for use with vovflowcompiler, the tool for packaging Flow.tcl scripts for inclusion in the Flow Library. You use these procedures in the Flow.tcl file you submit to vovflowcompiler to assign values to the metadata about the flow. These metatdata values are displayed to the user when they browse the Flow Library using the Add Flow CGI script.
These are the procedures:
| Tcl Procedure | Description |
| Description | Assign the description of the purpose of a flow |
| Keywords | Assign the keywords associated with a flow |
| Parameter | Assign characteristics of a parameter of flow. The facets you
can assign are:
| GetAllParametersFromTk | Get flow parameters from a Tcl/Tk application |
| GetAllPararametersFromHTML | Get flow parameters from a browser-based application |
| GetAllParametersFromCLI | Get flow parameters from a command-line application |
| RequiredFile | Test for presence of file needed by flow, copy from sample if any |
| RequiredDirectory | Test whether a directory needed by the flow exists |
