Search Log Files
vovsearchlog searches log files that are daily generated by server, taskers and daemons.
vovsearchlog
Search log files.
vovsearchlog: Usage Message
  DESCRIPTION:
      Search log files
  USAGE:
      % vovsearchlog [OPTIONS]
  OPTIONS:
      -h                  -- This help.
      -p                  -- Pattern in a regular expression.
      -d                  -- The number of days starting today and backward.
                             The default is 10 days.
                             If -s and -e are specified, this is ignored.
      -start              -- Start time of log files. Format is YYYYMMDD,
                             for example, 20171020.
      -end                -- End time of log files. Format is YYYYMMDD,
                             for example, 20171025.
      -f                  -- Each line starts with filename, otherwise
                             filename is printed once before searched
                             contents are displayed.
      -server             -- Search only in server logs.
      -tasker             -- Search only in logs from vovtasker, tasker
                             startup and vovtaskermgr.
      -daemon             -- Search only in daemon logs.
      -all                -- Search from any logs.
  EXAMPLES:
      % vovsearchlog -p ERROR -server -d 10
      % vovsearchlog -p ERROR -start 20170101 -d 30
      % vovsearchlog -p ERROR -start 20170101 -end 2017101
      % vovsearchlog -p 000021470
      % vovsearchlog -d 2
      % vovsearchlog -p "Job.*code" -d 30
      % vovsearchlog -p "termination?" -d 30 -tasker
  SEE ALSO THESE COMMANDS RELATED TO LOGS:
      vovcompresslog,   vovloghandler, vovcleanup
  SEE ALSO THESE COMMANDS THAT SHOW INFORMATION:
      vovjobqueue,      vovset list,   vovfind,
      vel,              voveventmon,   vovshowconnection,
      vovproject list,
      vovtaskermgr show
      vsi, vls, vst,
      vovdoc
