Impact of Changing a File or Node
The CLI Program vsc - Vov Show Consequences
The command line program vsc generates an "Impact Analysis" report to estimate the consequences of changing a particular file or node.
The name of this program was created to be the acronym for "Vov Show Consequences."
Impact of a Node Changing
When downstream jobs depend on an input file that changes, the downstream jobs must be run again. As they run, they can cause files to change which in turn trigger a need to run other jobs, and so on. All this downstream effect based on the dependency graph is known as the down-cone of a node.
The impact of a node is the total expected duration of the jobs that are rerun in its down-cone.
FlowTracer uses impact analysis to schedule jobs in the critical path ahead of the other jobs.
For efficiency reasons, FlowTracer uses an approximate calculation of the impact. In particular, for the purpose of job scheduling, all jobs with duration less than 5 seconds, are categorized as a "large" impact, thus saving the computation of a full and accurate impact.
vsc
This scripts performs "Impact Analysis" with VOV.
vsc: Usage Message
DESCRIPTION:
It shows the possible consequences of changing something
in the design. In general, the consequences are that all
dependent jobs must be executed again.
The report is a worst-case analysis, in the sense that
it is assumed that changes will propagate through all barriers.
(For an explanation of barriers, see clevercopy).
USAGE:
% vsc [options] <node_descriptor> ...
where the node descriptor is either the name of a file
or the VovId of a node in the dependency graph.
OPTIONS:
-help -- This message.
EXAMPLES:
% vsc a
% vsc 00023456 00023457
