FDL T_FINAL
- Arguments
- <none>
- Description
- T_FINAL indicates that the inputs and outputs declared through I and O commands associated with the last T declaration are the only inputs and outputs for that T. Any inputs and outputs that were associated with this T from a previous vovbuild but not declared again in this vovbuild will be removed.
