FDL SERIAL
Serially order a number of tasks and subflows (See also TASK and PARALLEL).
- Arguments
script- Description
- All of the tasks, jobs, and sets defined in the script are set up to be executed serially in the order they appear. Artificial dependencies are created between each task, job, or all the jobs in the set to build the graph serially. Can be nested in any order with sets, jobs, tasks, other SERIAL scripts, and other PARALLEL scripts. For examples see the TASK procedure.
