FDL S+
Append jobs to a set.
- Arguments
setname script- Description
- Append all jobs created in the body of the procedure to the specified
set. Note:
- If the specified set does not exist, the set is created.
- Job I/O nodes are not placed in the set.
- Must use fully qualified set name when appending to a nested set.
- Arguments
switch -- $arg { "-last" { vtk_set_operation $setid $make(lastNodeId) ATTACH } "-set" { set set2name [shift args] set set2id [vtk_set_find $set2name] vtk_set_operation $setid $set2id UNION } "-idlist" - "-id" { set idList [shift args] vtk_set_operation $setid $idList ATTACH } - Synopsis
S+ set_namebody - Examples
- Create the first Set
S "foo1" { J vw cp aa bb } - Append a second Set to the first using S+
S+ "foo1" { J vw cp bb cc } - Append Jobs to a Non-existing Set
- If you try to append jobs to a Set that does not exist yet, the Set is created by default, with the added jobs attached to it.
