FDL S
Precise definition of a set of jobs.
- Arguments
setname script args- Description
- Collect all jobs created in the body of the procedure in the specified
set. The S procedure can be nested. If the
setname at one level begins with a '+' sign or if
it has no colons (':'), the full name of the set is the concatenation of
the name of the set at the previous level, separated with a colon ':'.
If the name contains colons, it is considered to be a complete set name.
As of 2014.*, it is allowed for sets to contain other sets. Because of this, nested S procedures now attach the subset to the superset.Note: Job I/O nodes are not placed in the set.
- Synopsis
S set_namebody - Arguments
"-label" - "-gui_label" { set label [shift args] if { $label == "" } { vtk_prop_del $make(setId) GUI_LABEL } else { vtk_prop_set -text $make(setId) GUI_LABEL $label } } "-files" { S_update_files $setname } - Examples
- Single Set
S foo1 { J vw sleep 0 } ## ID001 - One nested Set (Set nested within a Set):
S foo2 { ## ID002 S bar2 { J vw sleep 0 } ## ID003 } - Using the Colon Syntax:
- Create a visual representation of a hierarchical set
structure, with only one job in one
Set:
S foo3:bar3 { J vw sleep 0 } ## ID003 - Create Sets Each Having Jobs using the Colon Syntax
- In this example, two Sets are created, and both will contain
jobs.
S foo4 { J vw sleep 0 } ## ID004 S foo4:bar4 { J vw sleep 0 } ## ID004
