FDL R2
- Arguments
resourceList- Description
- Similar to R, but this only applies to the most recently created job. That is, R goes before the T or the J, while R2 goes after the T or J. This procedure is used by the Vil-Tool VovResources when called with VOV_FDL_ONLY.
- Example
J vw cp aa bb R2 "res1 res2"
