FDL R
Set resources for subsequent jobs.
- Arguments
resourceList OPTIONAL_SCRIPT- Description
- Sets the resources required by the following jobs, i.e. the
R statement should precede T
or J. Takes one or two parameters. The first
parameter is a list of resource names. The second parameter, if present,
is a Tcl script which is executed in the context of the caller of the
R procedure. Side effect: sets the value of
make(resources), except when the second (script) parameter is given. - Example
R "unix" R "RAM#512" R "sun5 dc_shell_license" R "res1 res2 res3" R "res1 res2" { J vw cp aa bb } R {res1 res2} {puts "Resources = '$make(resources)'"}
