Declare an output dependency. All jobs require at least one output to be
valid.
- Arguments
[options] FILE FILE ...
- Description
- This is an output declaration. Its argument is a list of file names.
Each file is declared as an output of the job created with the most
recent J or T command. It is an
error to call O without having called J or
T first. Defining cyclic dependencies generates
an error. All jobs must have at least one output to be consider
valid.
- Option
- Description
- -db name
- Sets the
database
name of the output.
- -sticky
- Specify that the file is an output, even if it's not
actually a true output at runtime. Also useful if it is
truly an output, but is not instrumented or declared as
an output at runtime.
- -normal
- This option undoes the other options.
- -barrier
- Output may have a
barrier.
The barrier, if it exists, is controlled by the job that
generates this output.
- -force
- Force output declaration even with conflict.
- -noforce
- Fail on output conflict.
- -shared
- The output is shared.
- -md5
- Output has an automatic barrier consisting of its MD5
sum.
- -rcpc
- Same as -md5
- -ignore_timestamp
- Specifies that the timestamp of the file should not be
used to determine whether the job has succeeded or
failed.
- -quote
- Use the output name as given, instead of mapping it to
the corresponding logical canonical name.
