FDL J_FINAL
Similar to T_FINAL, J_FINAL indicates that the inputs and outputs declared through I and O commands associated with the last J declaration are the only inputs and outputs for that J. Any inputs and outputs that were associated with this J from a previous vovbuild but not declared again in this vovbuild will be removed.
