FDL INSTRUMENTED
- Arguments
command- Description
- Add a job that is implemented by a properly instrumented script, that is a script that outputs FDL if called with the VOV Instrumentation Library environment variable defined.
- Example
INSTRUMENTED ./mycopy aa bb
