FDL I
Declare an input dependency.
Arguments
[options] FILE FILE ...
This is an input declaration. Its argument is a list of file names. Each file is declared as an input of the job created with the most recent J or T command. It is an error to call I without having called J or T first. Defining cyclic dependencies generates an error.
Option
-db name
Sets the database name. The default is "FILE".
-sticky
Specify that the file is an input, even if it's not actually a true input at runtime.
-consumed
Specify that the input disappears if the tool completes successfully (e.g. the tool gzip consumes its input).
-normal
This option undoes the other options.
-quote
Use the input name as given, instead of mapping it to the corresponding logical canonical name.
-trigger,run
If the input changes, automatically run the downcone
-trigger,stop
If the input changes, automatically stop all jobs in the downcone
-noop
Ignored
-normal
Ignored
-links
Ignored in this context
I $inFile
I -consumed xx.tar
I -db PHANTOM net.h
