FDL_A
Add annotations to the most recently declared node.
- Arguments
note checkFlag- Description
- Adds Annotations to the most recently declared node, be
it an input, an output, or a job. If
checkFlagis true, the procedure checks the list of existing annotations in order to avoid duplicates. - Example
J vw sim $block.v $block.sti A "Run the simulation on block $block" I $block.sti A "The stimulus file" # The binary 'clevercopy' does not need a wrapper J clevercopy $file $goldDir A "Publish $file"
