Standard Environments
Most VOV installations offer at least the following environments:
| Environment Name | Description |
| BASE | A minimal environment for the basic operating system tools, X11, and VOV. This environment typically resets the PATH variable. Use this environment to cut the size of the PATH variable. |
| CLEAN | A destructive environment that eliminates most environment variable except a few essential ones. Normally used in conjunciton with some other environment, as in CLEAN+BASE. |
| CSHRC | The environment obtained by sourcing the ~/.cshrc file. Use this with caution, since many ~/.cshrc files fail to setup the environment properly, or have undesired side effects. |
| D | A parameterized environment used to define environment
variables. See also the environment 'U' to unset variables.
Examples:
| DOT | An environment that explicitly adds "." to the search path. Please remember that having a "." in the PATH is actually a security risk, so avoid using this environment if possible. |
| DEFAULT | An inactive environment. The use of this environment is discouraged, because it implies giving up on environment control. |
| M | Interface to the "modules" package. This environment
requires customization. The list of modules to load is
passed as a comma separated list of module names. Examples:
| SNAPSHOT & SNAPPROP | Use "snapshot" environments captured into a file or into a
property using the utility vovenvcapture. When
saved into a file, the environment can be used on a job by using
the SNAPSHOT environment which takes the file name as a
parameter, i.e. the job environment specification is
SNAPSHOT(name_of_the_file). If the
environment snapshot is saved as a property, the environment can
be used by specifying SNAPPROP environment, using the job
SNAPPROP(vov_id)When vovproject
start is executed, it automatically saves a
snapshot of the server's environment to a file inside the
server working directory.
| U | A parameterized environment used to undefine environment
variables. See also the environment 'D' to set variables.
Examples:
