Clean Directories
The tool vovcleandir is used to delete unused files.
vovcleandir analyzes the directories passed as arguments and then
enters an interactive loop in which you can choose to:
- list all files to be removed
- remove all or only selected files
- quit
With the option -force, vovcleandir removes all
unused files without asking for further input.
% vovcleandir -help
% vovcleandir
% vovcleandir -force
% vovcleandir *.vhdlWith the option -all, vovcleandir checks all
known directories for unused stdout and stderr
files.
% vovcleandir -all
vovcleandir
Clean up directories of all UNKNOWN files.
vovcleandir: Usage Message
DESCRIPTION:
Clean-up directories of all UNKNOWN files.
USAGE:
vovcleandir [options] [file_or_directory] ...
OPTIONS:
-all -- Cleanup all directories in which jobs are run.
-force -- Cleanup (delete) UNKNOWN files without asking
for confirmation.
-h -help -- Help usage message.
-silent -- Do not print the list of the deleted files.
If you do not indicate any file, this utility tests all ./.std.*
and all vovstd/* files.
Each file_or_directory argument is expanded according
to glob rules.
EXAMPLES:
% vovcleandir -help
% vovcleandir .
% vovcleandir -all
SEE ALSO:
vovcleanup -- to cleanup old log files from host and project
nc clean -- to cleanup old files generated by Accelerator
