Configuration .tcl Files
Configuration of FlowTracer on a per-project basis is handled by four .tcl files: policy.tcl, security.tcl, resources.tcl, and taskers.tcl.
policy.tcl
The policy.tcl file sets various server variables, such as the
max number of Smart Sets, or max jobs in parallel. The syntax is as
follows:
vtk_user_set <user> -weight <n> -defaultpriority <n> -maxpriority <n>
vtk_group_set <group> -weight <n> -users { <list_of_users> }
vtk_swd_set <symbolic> <path>security.tcl
security.tcl defines who has access to the FlowTracer server. The main procedure used to define the "security rule"
is:
vtk_security <username>|-group <vovusergroup> <securityLevel> <hostlist1> ...- <username> is the login name of a user
- <vovusergroup> is the name of a VovUserGroups
- <securityLevel> is either USER, LEADER, or ADMIN, case insensitive
- <hostList> is a list of one or more of <hostName>, where <hostName> is either the name of a host, + meaning any host, or - meaning no host.
resources.tcl
resources.tcl defines both the rules to dispatch jobs based on
priorities, as well as the number of licences available for tools used within your
flow. The syntax is as
follows:
vtk_tools_map <licence> <NUMBER> "rule"
vtk_resources_map <licence> <NUMBER> "rule"
vtk_resources_map <PRIORITY> <NUMBER>
vtk_toolmap_set <licence> <NUMBER> "rule"
vtk_resourcemap_set <User:> <NUMBER>
vtk_resourcemap_set <Group:> <NUMBER>taskers.tcl
The taskers.tcl file defines the taskers for FlowTracer to use. The syntax
is:
vtk_tasker_define hostname [options]
