Procedure Descriptions
This section describes the VOV Tcl CGI procedures in more detail, describing the arguments and actions of each.
Note: The names of these procedures are mainly taken from the type of HTML tag which
they implement, to make them easy to remember for persons familiar with HTML.
Again, they are not HTML tags; each of the following is a Tcl procedure which
takes zero or more arguments, so the script that you write using them must be in
valid Tcl syntax.
Pay special attention to this for any parameter which is named args or script. See the description of the TABLE procedure and the example scripts for more information.
VOVHTML_START {}
- Description
- The VOVHTML_START procedure begins a new HTML page. It opens a temporary file to receive the text of the page. This procedure must be called before any of the following ones.
- Arguments
- None
VOVHTML_FINISH {[contentType HTMLtype]}
- Description
- The VOVHTML_FINISH procedure closes a HTML page. It writes the HTML header information, then the text which was stored in that page's temporary file, and removes the file.
- Arguments
- content-type (optional); default is text/html
OUT {text}
- Description
- The OUT procedure adds the text of its argument to the page, without a newline.
- Arguments
texttext to insert into the page
OUTLN {text}
- Description
- The OUT procedure adds the text of its argument to the page, with a newline.
- Arguments
HTML {script}
- Description
- The HTML procedure builds the HTML section of the page, starting with the <html> tag, the text of the page, and then closes it properly with the </html> tag. It executes the Tcl script passed as its argument, and inserts the resulting text into the page.
- Arguments
scriptTcl script that builds the HTML of a page
TITLE {title}
- Description
- The TITLE procedure inserts its text as the page title in the HEAD section of the page.
- Arguments
titletext of page title
BODY {script}
- Description
- The BODY procedure executes the Tcl script, and inserts the text which the script returns as the page body in the BODY section.
- Arguments
scriptTcl script that builds text to form the page body
COLOR {color text}
- Description
- The COLOR procedure surrounds its text argument with HTML code so that it will display using the named color.
- Arguments
colorHTML color name or #codetexttext to be displayed incolor
FONT {args}
- Description
- The FONT procedure surrounds its text argument with HTML code so that it will display using the named color. All except the last argument are taken as attributes of the FONT tag.
- Arguments
argstext to be displayed in using the namedfont.
SPAN {args}
- Description
- The SPAN procedure defines a region of args to which a style rule may be applied.
- Arguments
argsvariable-length argument list.
FORM {args}
- Description
- The FORM procedure defines an HTML form for user interaction.
- Arguments
argsattributes and Tcl script defining the form
SCRIPT {text}
- Description
- The SCRIPT procedure inserts its text as the code of a script into the current page. Typically, the code will be JavaScript.
- Arguments
texttext to be inserted as script code
OPTIONS {args}
- Description
- Inserts an OPTION element into the current SELECT element. Must be used in the scope of a SELECT.
- Arguments
SELECT {args}
- Description
- Inserts an SELECT element into the current FORM. Must be used in the scope of a FORM. The SELECT element forms a one-of-many choice using a drop-down list. Each item in the list is defined by an OPTION item.
- Arguments
VOV_SET_COOKIE {name value [expires]}
- Description
- Store a cookie in the browser memory for future reference.
- Arguments
namethe name of cookie to be storedvaluethe value of cookie to be storedexpires(optional) the expiration timestamp of the cookie. Without this argument, the cookie will survive the session, i.e., the cookie expires after all browser windows are closed.
VOV_GET_COOKIE {name}
- Description
- Retrive a cookie value.
- Arguments
namethe name of cookie to retrieve
- Returns
- value the value of the cookie retrieved or blank("") if no cookie with name name is found
TABLE {attributes} script
- Description
- Defines a table in the current HTML page. The table may contain nested TR, TH, and TD procedures.
- Arguments
attributesfor the table, such as ALIGN="CENTER" BORDER="1" etc.scriptTcl script that builds the rows of the table.
- Returns
TR {attributes} script
- Description
- The TR procedure defines a row in a table. It must appear in the scope of a TABLE procedure.
- Arguments
attributesoptional attributes for the row (e.g. bgcolor)scriptTcl script that builds the content of the rows.
TH {attributes} script
- Description
- The TH procedure defines a header cell in a table. It must appear in the scope of a TR procedure. The text of a table header cell is formatted bold and is centered in the cell.
- Arguments
attributesoptional attributes for the cellscriptTcl script that builds the content of the header cell.
TD {attributes} script
- Description
- The TD procedure defines a table data cell in a table. It must appear in the scope of a TR procedure. The text of a table data cell is formatted plain and is usually aligned to the top left of the cell.
- Arguments
attributesoptional attributes for the cellscriptTcl script that builds the content of the cell.
HREF {url label}
- Description
- The HREF procedure defines a hyperlink in the current page.
- Arguments
urldestination URL of the linklabelvisible label of the link, which appears in the current page
BR {}
- Description
- The BR procedure begins a new line in the current page.
- Arguments
- None
HR {}
- Description
- The HR procedure inserts a horizontal rule (line) into the current page. The width of the line will vary as the window displaying the page is resized.
- Arguments
- None
Section Header Procedures
HTML defines six section header styles, ranging from H1 through H6, with H1 being the
most emphatic (largest point size, and bold-face), and H6 being the least emphatic.
VOV provides the corresponding H1 through H6 procedures.
- H1 {script}
- The H1 procedure evaluates its script as a Tcl script, and inserts the resulting text, surrounded by H1 tags, into the current page.
- H2 {script}
- The H2 procedure formats its text using the Header2 style.
- H3 {script}
- The H3 procedure formats its text using the Header3 style.
- H4 {script}
- The H4 procedure formats its text using the Header4 style.
- H5 {script}
- The H5 procedure formats its text using the Header5 style.
- H6 {script}
- The H6 procedure formats its text using the Header6 style.
Other Formatting Procedures
VOV CGI also provides procedures to support other common formatting requests,
including:
- B display text boldface
- EM display text emphasized
- TT display text in TTY (fixed width) font
- BIG display text in larger size
- SMALL display text in smaller size
- P start a new paragraph
- OL start a ordered (numbered) list
- UL start an unordered (bulleted) list
- LI start a List Item in an ordered or unordered list
- PRE start section of pre-formatted text (displayed in TTY font, not flowed)
The procedures described are defined in VOVDIR/tcl/vtcl/vovhtmlgen.tcl.
