Project Home Page
When you enter the URL to access the browser interface you will start the web application to manage the system. The first page of the web application is the Project Home page. It offers a top-level menu of features you can navigate.
The six major areas of managing the system are accessible by clicking on the names in the headers of each of the six tables in the display.
Trace
Drill down to see information about the job and file nodes registered with the project. The breadcrumb navigation shows that this view comes from looking at the members of the all-inclusive set, System: nodes. This is the system-defined set that holds all nodes in the graph.
Sets
Sets is a way of grouping nodes in the dependency graph by gathering together nodes that match the selection rules for the set. That group of nodes can be accessed by viewing the members of that set. Each set name in the list provides a link to navigate to the Set Detail page.
Taskers
Workload
Resources
Each row in the table provides links to see details about each resource. The tabs across the top of the System Monitor page lead to other panels showing details about those elements.
Administration
This page is aimed at the Administrator User. You can learn more about the Administrative functions available in this section of the application in the Administrator's manual.
- Configuration Parameters
- The FlowTracer system uses Configuration Parameters to
manage actions and behavior and to constrain various resources. The page
showing the set of Configuration Parameters is accessed by clicking
Server Config Params from the lower left side on
the main page
Figure 8.
- Adding More Clients
- As a user you may reach the maximum number of clients allowed per user with FlowTracer. This maximum number is controlled by the maxNormalClients configuration parameter, which is set to a default value of 400. This configuration control is used to protect against a Denial of Service attack.
