Types of Buildings
Four different types of buildings are possible. The different types of buildings are:
- Standard buildings
- Standard buildings can be used to model a building in an urban environment.
- Horizontal Plates
- Horizontal plates can be used to model horizontal objects in an urban environment that have a certain thickness but do not reach the ground (for example, bridges).
- Courtyards & Towers
- This type of building is used to define a building which is totally inside another building. If the inner building is higher this is called a tower and if it is lower it is called a court.
- Vegetation buildings
- This type of building is used to model vegetation (for example, parks, trees). The building is transparent (the rays have no interactions like reflection or diffraction at the vegetation building).
- Virtual buildings
- With this type of building only pixels are excluded from the prediction (all pixels inside virtual buildings are not computed to accelerate the prediction and reduce the memory requirements). The virtual buildings are transparent for all prediction models. So, the rays can pass the building without any additional loss. Only pixels inside the virtual buildings will not be predicted to save computation time.
| Type | Standard | Horizontal Plate | Tower | Vegetation | Virtual |
| Interactions with rays (refl., diff.) | Yes | Yes | Yes | No, transparent | No, transparent |
| Prediction of pixels inside | Only with special indoor models | No | Only with special indoor models | Yes, but with add. attenuation [dB] | No |
| Rays through the building | No | No | No | Yes, with add. attenuation[dB/m] | Yes, no add. attenuation |
| Material properties | Standard Set (Permittivity, Permeability, Conductance, Reflection Loss, Transmission Loss, Diffraction Loss) | Standard Set (Permittivity, Permeability, Conductance, Reflection Loss, Transmission Loss, Diffraction Loss) | Standard Set (Permittivity, Permeability, Conductance, Reflection Loss, Transmission Loss, Diffraction Loss) | Additional attenuation for pixels [dB] Additional attenuation of rays [dB/m] |
Properties not relevant |
| Building Type ID | 0 | 31 | 3 | 2 | 1 |
