In additional to creating simple searches using a single search query, you can create
complex combination queries using the logical operators (AND/OR).
Example One - OR Operator
You want to search for all the parts that were modified. This can be done by checking for a
value in the
Change Reason attribute of a part or some value in the
Change Detail
attribute of a part. The combination query will be created as follows:
Table 1. Combination Query
AND/OR |
Parenthesis |
Attribute |
Operator |
Values |
Change Reason |
IS NOT NULL |
OR |
Change Detail |
IS NOT NULL |
This combination query displays the parts that were modified.
Example Two - AND Operator
satisfy the following conditions at the same time:
- Code is not NULL
- Revision is 'metro'
- Description begins with 'A-'
- Unit weight is between 1 and 10 kg
This can be done using the following set of queries combined using the AND operator:
Table 2. Combination Query 1
AND/OR |
Parenthesis |
Attribute |
Operator |
Values |
Code |
IS NOT NULL |
AND |
Revision |
metro |
AND |
Description |
LIKE |
'A-*' |
AND |
Unit Weight |
1 |
AND |
Unit Weight |
10 |
This combination will give the list of the parts that are required.
Table 3. Combination Query 2
AND/OR |
Parenthesis |
Attribute |
Operator |
Values |
Code |
IS NOT NULL |
AND |
Revision |
metro |
AND |
Description |
LIKE |
'A-*' |
AND |
AND |
Unit Weight |
1 |
AND |
Unit Weight |
10 |
This combination is similar to the previous combination except that it uses parentheses
to make it more readable.
Example Three - AND and OR Operator
You want to search for all the parts that have the description starting with 'GREASE', and
with either Revision as 'WA' or having code in 'AIRBUS'. This can be achieved using the
following search combination query:
Table 4. Combination Query
AND/OR |
Parenthesis |
Attribute |
Operator |
Values |
Description |
LIKE |
GREASE* |
AND |
Revision |
WA |
OR |
Code |
IN |
AIRBUS |
Note: The logical AND operator has higher precedence than the
logical OR operator..
