Solid conductors can be used for machines with skewed topologies
The wires can be considered as solid conductors when the stator or the rotor are skewed.
Example of a machine with a skewed stator defined in Motor Factory
The solid conductors can be considered while exporting projects from FluxMotor to Flux Skew as well as in the back end of Motor Factory for computing the machine performance.
Exporting a machine with a skewed stator in Flux Skew is possible with represented coil conductors (One phase or All phases) and the resulting model in Flux Skew
