Synchronous machines – Motor Factory – Test environment
1. Duty cycle with many working points fails
Running a computation of a duty cycle with many working points via scripting crashes (ref.: FXM-14435).
This issue has been corrected.
2. FMU LUT data Export: Flux_D and Flux_Q are incorrect
The flux linkage related to the end winding inductances on FMU side is not considered, as it is done on the test map side (ref.: FXM-14041).
