Visualize the Heat Distribution
The next step is to visualize the heat distribution through conduction between hot and cold particles.
To visualize the heat distribution:
  1. Expand Display in the Analyst Tree.
  2. Select Geometries and select Mesh from the Display Mode dropdown list.
  3. Select Particles and select Temperature from the Color by dropdown list.
  4. Select the Show Legend checkbox.
  5. Set the Min Value: and Max Value: of temperature to 300 K and 500 K respectively.
  6. Click Apply All.
  7. Rewind the simulation to play it back from the beginning.
