Review the Simulation
The last step is to review and run the simulation.
- Using the Viewer Controls, set the Step Factor to Time and Value to 0.02 s.
Play the simulation again.
Note: A hot ball is created followed by two cold balls. Heat is transferred over time between the three balls as shown in the following images at two different Time Steps:
You can modify the display further and also extend the simulation time to be established when all the particles would reach the same temperature state.
