EDEM Creator - Set up the Model
Learn how to set up a simulation model and equipment, and define the generation of bulk materials using EDEM Creator.
Open
Rock_box.demfrom Part 1. - In EDEM Analyst, set Current Time to 0 s.
- Select .
Select a location (e.g.
C:\EDEM_Tutorials) and file name (e.g.Rock_box_full.dem) and click Save. -
In the Export Options dialog box, leave the default
settings.
Note: This will create the simulation file at t = 0 s. An input deck can be taken from any point in a simulation. It is recommended to take the input from the last Time Step to store the simulation results or share with other users. This is a single Time Step and smaller in file size than the full simulation.
Close this file and open
Rock_box_full.demfrom the folder.
Define the Base Particles
The first step is to define all the types of particles used in a model in the Bulk Material section.
- Define the base particles.
Create new particle shapes - two multi-sphere shapes and one polyhedral
shape.
- In the Bulk Material section, select and expand rock.
- Right-click the GEMM particle shape and select
Delete Particle.
A warning message indicating deletion of the associated factory is displayed.
- Click OK.
- Right-click rock and select .
- Enter the name rock particle_1 into the highlighted field, and repeat the same steps to add another Multi-Sphere particle rock particle_2.
- Select to create a third shape rock particle_3.
Define the spheres and properties.
Multi-Sphere Particles are made up of one or more spheres. In this case, we shall import CAD templates of rock particles of different shapes and fit spheres to the template.
- Select .
- Click Import to import the particle templates
Rock_Template1.stlandRock_Template 2.stl. - In the Import Options dialog box, set the measurement units to mm, and ensure that all the settings have the default values.
- Click OK.
- Click the
icon and rename the templates to
Rock_Template1 and
Rock_Template2, and then click
OK. - To view the template, select rock particle_1 from the Creator Tree.
- On the lower-right corner, select Rock_Template1
from the Display Templates dropdown list.Note: The template will appear larger compared to the spheres until the next step is completed.
- Select rock_particle1 in the Bulk Material section.
- Modify the rock particle_1 Spheres section as
follows:
Table 1. Radii and positions of spheres Particle Name rock particle_1 rock particle_2 Sphere 0 1 2 0 1 2 Radius (mm) 25 25 25 25 20 20 Position X (mm) 0 -17 17 0 16 -16 Position Y (mm) 19 -9 -9 2 -8 -8 Position Z (mm) 0 0 0 0 0 0 - Select user-defined from the Size
Distribution dropdown list.
- Click Import and select
PSD.csv.This will set the size distribution as in the csv file.
- Select Properties and click Calculate Properties.
- Repeat the same steps for the second Multi-Sphere particle.
- Select user-defined from the Size Distribution dropdown list.
- Select Properties and click Auto Calculation.
- Set the Cuboid Box Length X,Y,Z values to
50 mm. The following shapes are generated by the templates:
Note: Three different particles have been created to highlight the types of rock particles shapes.
Create the Particle Factory
The next step is to create a dynamic factory that produces particles over the duration of a simulation.
- Expand Geometries in the Creator tree and right-click factory_plate.
Specify values for the creation of the particle factory particle.
In this model, all the three rock particles are to be created at a rate of 100 kg per second.
- Select Dynamic from the Factory Type dropdown list.
- Select Unlimited Number.
- In the Generation Rate section, select Target Mass and set the rate to 300 kg/s.
- To ensure that this corresponds to each particle being generated at 100
kg/s, select rock in the Bulk Material section of
the Creator Tree.Note: The Particle Ratios section shows an even composition of the three rock particle types (33.33333% each).
Set the initial parameters for the factory.
- Select the newly created factory (e.g. New Factory 2) in the Creator Tree.
- Ensure that the Factory Type is set to Dynamic.
- If the Factory Type is set to Static, right-click the factory and select Change Factory Type.
- Set the Velocity to Fixed
and then click the
icon to set the velocity in the X-direction to 3.54
m/s.
