EDEM 1020 Rock Box - Part 1
This tutorial describes the simulation setup suitable for using the Altair Student Edition. This simulation can be set up quickly with low simulation time (~2 minutes on 2 CPU cores).
Objective
The objective of the Rock Box tutorial is to:
- Use the GEMM database
- Create multiple particle types and shapes
- Use mixed shapes (Polyhedral particles and Multi-Sphere)
- Import a particle size distribution from a
*.csvfile - Implement conveyor kinematics to the conveyor Geometries
The model used in this tutorial is a rock box.
Important: You must download the
simulation and associated CAD files (
rock_box1.stl,
Rock_Template1.stl and Rock_Template2.stl before
starting the tutorial. In addition, a particle size distribution file is
available (PSD.csv). It is recommended that you copy these
files to the same location as the simulation files. To download the simulation
files for this tutorial, see Download
Simulation Files.
