Starting an Application on the Application Page
Users with a Designer role have the ability to open and manage applications.
- On the Applications tab, click an application link to open and display it on the Application page.
- Click
to run the application.
The
button changes to
and the Running status displays.
The stream topics and the data producer are generated.
- You can also perform the following:
- Click on a node in the Graph pane to display its Operator Settings as well as the preview of the data (OUTPUT) in the Schema pane
- Click the Metrics tab to display the node’s Metrics as well as the preview of the data (OUTPUT) in the Schema pane
- Select an input or output node and click the Data Preview tab to display the data preview.
You can also click:
to copy the data to a clipboard.
to pause the update. To start the update, click
