Removed Reports
Monarch Server provides possibility to view the following information about reports that were removed from Read-Only volumes:
Availability of a First Copy and a Second Copy at the moment of deletion
File name
Filing date
Document date
File size
Report name
To view removed reports
On the Navigation Tree, click System Reports and select Removed Reports.
In the Document date: From ... To fields specify a time period for the document dates to be included in the report. Click
to open the Calendar window, and select the date. -
From the Volumes list, select a read-only volume, from which reports were removed.
From the Document Types pane, select a document type that contained removed reports.
Click View.
To print the report, click the
icon at the top of the page, then click OK in the Print dialog box.
NOTE: For information on how to convert a report to another format, see Converting a report to another format.
