Security Options
Use this window to specify whether you want to save the passwords for imported databases in projects or models, and whether you want to save passwords from PDF files in projects.
To access this window select Options from the Home ribbon, then select Security from the Options Window ribbon.
NOTE: Passwords are saved using 1024-bit RSA encryption.
Options
Field |
Description |
Save passwords from imported databases in projects and models: |
Save passwords from PDF files in projects: |
When you open a password-protect PDF file, the PDF Password dialog displays. You must enter the correct password to the PDF file to continue opening it. |
Save login credentials in projects |
Save passwords from archives in projects |
Login Credentials |
Allows you to specify a default user name and password to be applied when using files from SharePoint (HTTP) and FTP locations, Amazon S3, and Tableau Server. To enable saving to HTTP and FTP locations, the following credentials must be provided:
For saving to HTTP locations, you can select the Use Current Windows Login checkbox to apply the current Windows credentials.
To enable saving to Amazon S3, the following credentials must be provided:
To enable exports to Tableau Server, the following credentials must be provided:
General
Field |
Description |
Make these the default settings |
Saves the current settings in the Registry as the defaults for future Monarch Classic sessions. NOTE: When closing the current model you will be prompted to save the model changes. You must select Yes to save the tab settings as the defaults. If you choose not to save the model changes, the tab settings will not be saved as the defaults. |
Restore from default settings |
Restores the settings to the default values previously stored in the Registry. |
