Export Options
Use this window to specify options for exporting data from the Table or Summary window.
To access this window select Options from the Home ribbon, then select Export from the Options Window ribbon.
Export Field Names
Field |
Description |
Include field names as the first row of output |
Use this setting to export the Table window field names (or Summary window column titles) when exporting data to a text file, a delimited text file or HTML formats. Note: Field names are always exported to database formats, dBASE DBF format, and MS-Access MDB format and to spreadsheet formats (XLS) when exporting via the Jet database engine. They are also always exported to XLSX and XLS when using the Monarch Classic 10.5 Engine. |
Repeat field names on each page (Applies to fixed-width text files with pagination enabled) |
Exports the Table view field names (or Summary window column titles) to each page when exporting data to a fixed-width text file with pagination enabled. |
Get column names for summary exports to database formats from: |
When exporting a summary to a database, specify where you want to get the column names from -- i.e., from either the Table window field names or the Summary window column titles -- by selecting the appropriate option..
Export Excel Files
Field |
Description |
Apply formatting to XLS and XLSX files |
Use this setting to reflect Monarch Classic's formatting as far as possible when exporting to Excel. This creates only a very small performance impact. |
Apply the Export Wizard’s "Advanced Excel Features." |
Enables exports from the Summary using Excel Formulas, Excel Conditional Formatting Rules, and Outlining. It also enables the AutoFilter and Pivot Table options when exporting from the Table view. |
Export Text Files
Field |
Description |
For Report Text Files option |
Insert page breaks |
Use this setting to indicate where page breaks will be added in the export file or to not add page breaks at all. The following options are available:
For Fixed-length Text Files options |
Pad each field with n extra space(s) |
Use this setting to separate exported fields with extra spaces when exporting to a text file or a delimited text file. With this option unselected, field values might "bump up" against each other producing, for example, "123.45CD" rather than "123.45 CD". |
Pad numeric fields with zeros, suppress the decimal point, and use trailing negation |
Use this setting to export numeric fields using a standardized format that pads each value with leading zeros, removes the decimal point and places the negation sign at the end of the field value. This format represents the number "-123.45" as "00012345-". When selected, this option reformats each numeric field whose type is set to "Numeric" (as opposed to Thousands, Currency, or Percentage), removing the decimal character, and then padding the field with sufficient leading and trailing zeros to match the field’s column format, preserving the rightmost character position for a trailing negation sign. |
Insert a page break after n lines |
Use this setting to add page breaks to a file at regular intervals by specifying the number of lines you want on each page. |
For Delimited Text Files options |
Put "Quotes" around character field values |
Use this setting to enclose character fields in quotes when exporting to a delimited text file. Why Enclose Character Fields in Quotes? - A comma is the most common field delimiter used in delimited ASCII files. Since commas are often used in description fields, a field value such as "Brahms, Symphony No.1" might be interpreted as two consecutive field values - "Brahms" and "Symphony No.1". By enclosing character fields in quotes, the value would be correctly interpreted as a single field, "Brahms, Symphony No.1". When a character field value includes a quote character, Monarch Classic appends a second quote character immediately following the original. This allows an application reading the delimited text file to interpret an individual quote character as designating the end of a string and a pair of quote characters as designating an individual quote character within a string. |
Put "Quotes" around field names on the first row |
This encloses the data on the first row of the file in quotes. As a rule, this data will be the field names. This option is provided to enable compatibility with systems that expect the data in this format. |
Delimiter |
Select the appropriate radio button to specify the character to use for separating field values when exporting to a Delimited Text file. Note: The most common delimiter character is a comma. When selecting the Other option, enter the desired character in the adjacent field. |
Date format |
Select the preferred format for exporting date values. Valid options are yyyy-mm-dd and yyyymmdd. |
For both Fixed-length and Delimited Text Files options |
Append DOS end-of-file character (x1A) |
This option determines whether or not a DOS end-of-file character (x1A) is appended to the end of the file. This option is provided to enable compatibility with systems that expect the data in this format. This end-of-file character is often known as Control-z. |
Encoding |
Use this setting to specify the default export format. The following encodings are supported by Monarch Classic:
Code page |
Select the appropriate code page to use with the chosen input file encoding format. This option is only applicable to the ASCII (14 codepages available) and ANSI (10 codepages available) encoding systems. |
DB and DBF Files
Field |
Description |
DBF Files |
Displays the file format and version to be used when exporting dBASE DBF files. The drop-down list includes all supported versions of the dBASE DBF file format. |
MDB Files |
Displays the file format and version to be used when exporting Access MDB files. |
Report View - File Naming
Field |
Description |
Default Naming Prefix |
Sets a default filename prefix for exported reports. |
Separator |
Specifies a separator between the filename prefix and body. |
Default Naming Body |
Sets a default filename body for exported reports. |
Separator |
Specifies a separator between the filename body and suffix. |
Default Naming Suffix |
Sets a default filename suffix for exported reports. |
Preview |
Provides a preview of the final report filename. |
Table View - File Naming
Field |
Description |
Sets a default filename prefix for exported tables. |
Separator |
Sets a default filename body for exported tables. |
Separator |
Sets a default filename suffix for exported tables. |
Preview |
Provides a preview of the final table filename. |
Summary View - File Naming
Field |
Description |
Sets a default filename prefix for exported summaries. |
Separator |
Sets a default filename body for exported summaries. |
Separator |
Sets a default filename suffix for exported summaries. |
Preview |
Provides a preview of the final summary filename. |
Table View - Table Naming
Field |
Description |
Sets a default table name prefix for exported tables. |
Separator |
Specifies a separator between the table name prefix and body. |
Sets a default table name body for exported tables. |
Separator |
Specifies a separator between the table name body and suffix. |
Sets a default table name suffix for exported tables. |
Preview |
Provides a preview of the final table name. |
Summary View - Table Naming
Field |
Description |
Sets a default table name prefix for exported summaries. |
Separator |
Sets a default table name body for exported summaries. |
Separator |
Sets a default table name suffix for exported summaries. |
Preview |
Export Options, General buttons
Field |
Description |
Make these the default settings |
Saves the current settings in the Registry as the defaults for future Monarch Classic sessions. Note: When closing the current model you will be prompted to save the model changes. You must select Yes to save the tab settings as the defaults. If you choose not to save the model changes, the tab settings will not be saved as the defaults. |
Restore from default settings |
Restores the settings to the default values previously stored in the Registry. |
