Altair Monarch Server Library Options
Use this window to specify an Altair Monarch Server Library from which to access and save projects and models.
Security Options
Field |
Description |
Location |
Specifies the location of the Monarch Server Library from which you can open files and to which you can save models and projects |
User |
Identifies an authorized user of the library |
Password |
Specifies the password required to access the library |
Single Sign-on |
Uses single sign-on to access the Monarch Server Library |
Update |
Updates and saves the specified credentials |
Set as default |
Uses the specified server and credentials as the default setting for saving models and projects |
Remove |
Removes the specified credentials |
Default Save Project and Save Model behavior |
Specifies whether or not the Server library is to be used when saving projects and models.
