Other Connection Options
Most Monarch Data Prep Studio connector dialog boxes provide a text box that allows you to enter additional connector options:
Notes:
If you need multiple string connection options, separate these by a semi-colon. Use the form: Option1=[value];Option2=[value];
You can only enter up to a maximum of 512 characters into this text box.
Options and valid values for specific connectors may be found here:
Connector |
Options and Values |
Amazon EMR Hive |
Amazon Redshift |
Cassandra |
Cloudera CDH Hive |
Cloudera Impala |
DB2 |
https://docs.progress.com/bundle/datadirect-ibm-db2-odbc-80/page/Connection-option-descriptions.html |
Google BigQuery |
Hadoop Hive |
Hortonworks Hive |
HubSpot |
Informix |
MapR Hive |
MySQL |
NetSuite |
https://docs.devart.com/odbc/netsuite/connection_options.htm |
MongoDB |
https://www.mongodb.com/docs/drivers/csharp/current/fundamentals/connection/connection-options/ |
Oracle |
https://docs.progress.com/bundle/datadirect-oracle-odbc-80/page/Connection-option-descriptions.html |
PostgreSQL |
ServiceNow |
SharePoint |
Spark SQL |
SQL Azure |
SQL Server |
Sybase IQ |
Teradata |
