Connector Dialog for SharePoint
NOTE: This connector requires a Java Virtual Machine (JVM) to work. If it is not available on the connectors list, follow these steps to enable it:
Enter values into the dialog box to connect and fetch data from your ServiceNow data source. Select a specific tab to display specific options.
| Connection Tab | |
Fill out the fields below to initiate a successful connection. Bold fields are required.
Field |
Description |
Service URL |
Enter the endpoint for the Microsoft SharePoint service to which you are connecting. |
Authentication Method |
Determines the authentication method to be used during the course of the session. Select the method from the drop-down list. |
Client ID |
Enter the client ID key for your application when authenticating to REST endpoints with OAuth 2.0 enabled |
Client Secret |
Enter the client secret for your application when authenticating to REST endpoints with OAuth 2.0 enabled. Important: The client secret is a confidential value used to authenticate the application to the service. To prevent unauthorized access, this value must be securely maintained. |
Access Token |
Enter the access token used to authenticate to REST endpoints with OAuth 2.0 enabled. Typically, this option is configured by the application; however, in some scenarios, you may need to secure a token using external processes. In those instances, you can also use this option to set the access token manually. Note: You can use the Copy/Paste icon |
Refresh Token |
Enter the refresh token used to either request a new access token or renew an expired access token for OAuth 2.0 implementations. Important: The refresh token is a confidential value used to authenticate to the service. To prevent unauthorized access, this value must be securely maintained. Note: You can use the Copy/Paste icon |
Authorization URI |
Enter the endpoint for obtaining an authorization code from a third-party authorization service for OAuth 2.0 implementations. |
Token URI |
Enter the endpoint for retrieving access tokens when OAuth 2.0 authentication is enabled. |
Scope |
Enter a space-separated list of OAuth scopes that limit the permissions granted by the access token. |
Redirect URI |
Enter the endpoint to which the client is returned after authenticating with a third-party service when OAuth 2.0 authentication is enabled For some authentication flows, the REST service will redirect you to a third-party service for authentication. Once your credentials have been validated, the third-party service returns the client to an endpoint in the REST service to continue the session. The endpoint used by the third-party service is provided by the client and specified using the Redirect URI option. |
Reset Connection |
Check this box to reset the OAuath connection and fetch new access tokens. |
TEST CONNECTION |
Click to initiate a connection and test the values you have entered. If there are errors, messages will be displayed beside this button. Notes:
| Tables and View Tab | |
Tables and Views |
Allows you to load, and then select, the tables from your database by manually selecting from a list. To load tables and views via search and select:
Note: If you wish to add a duplicate column, select this column from the Add a duplicate column drop-down list provided.
To select a column: Check the boxes beside the columns you want to use. If you want to use all columns check the Column box on the header.
To aggregate columns:
If the data returned are to be aggregated, check the Aggregate box on the header, then select the aggregation method you want to use for each column. The following aggregation methods are possible for each data type:
To filter columns:
If the data returned are to be filtered, check the Apply Filter on the header. Then, for each column, select a filter method from the filter drop down and then enter the filter value in the Filter Value box. Notes:
Preview Data |
Click to fetch data using the credentials and criteria you have specified. This allows you to confirm your connection, ensure you have connected to the correct table, check your query, and verify the information that will be loaded. Notes:
| Query Tab | |
Query |
Allows you to load, and then select, the tables from your database by entering a SQL Statement. If you already selected Tables and Views, this box is updated to show the corresponding SELECT * FROM TABLE query.
If you want to define the query, enter the SELECT, EXEC, and/or WITH statements to execute. Notes
Preview Data |
OK/CANCEL |
Select OK to establish the connection and fetch data or Cancel to close the dialog. The state of the OK and PREVIEW buttons provides a handy status about the state of your connection:
