Clipboard Options
Use this window to specify how Monarch Classic copies data from a document to the system clipboard.
To access this window select Options from the Home ribbon, then select Clipboard from the Options Window ribbon.
Clipboard Options
Field |
Description |
Include field names as the first row |
Use this setting to export the Table window field names (or Summary window column titles) when exporting data to the Clipboard. |
Text Format: |
Pad each field with one extra space |
Adds a space after a fixed-length text field. |
