The next checkbox is Set Analysis Requirements.
In the step, you will have to answer a series of questions to describe the model under consideration. Each equation has only two valid answers and the dialog will help you pick one of them. These requirement questions are grouped together.
This page has all the questions related to model and type of analysis.
Process Data dialog |
This page includes few analysis questions.
Analysis Data dialog |
This page has advanced meshing control questions.
Advanced Meshing Data dialog - Optional |
In this page:
Right click on each item to assign it to the highlighted object.
In this page, select the inlet and outlet surfaces for each layer of Polymers. Click Next to proceed to the next page.
Select the BC parameter data. Click OK to save and close the Set Analysis Requirements tab.
Click OK to save all the selections of the Set Analysis Requirements tab. |
