Dielectric Resonator Antenna on Finite Ground
Calculate the input impedance and radiation pattern of a dielectric resonator antenna (DRA) with a coaxial pin feed on a finite ground.
Model the dielectric layers using the following configurations:
- Feed with a FEM modal source and solved using the hybrid finite element (FEM) and MoM solution.
- Feed with a waveguide source and solved using the method of moments (MoM) solution with the surface equivalence principle (SEP).
- Conduct characteristic mode analysis on the structure (lossless and lossy) and observe the consequent degradation of the modal significance in the lossy case.
